Can you rate-limit OneDrive Sync
thedutchmans
Post by thedutchmans »
I have OneDrive sync working. However, it uses all of my internet bandwidth when it runs (70Mbps). Using SSH, it looks like you're using rclone to connect to OneDrive. Where is the rclone config stored? I'd like to try to rate-limit it to 10Mbps.
Re: Can you rate-limit OneDrive Sync
We will check here and get back to you later.
thedutchmans
If you could just private message where the rclone mounting command is stored, I can edit it myself.
We have check that it's not allowed to rate-limit OneDrive as you required,
thedutchmans
Rclone has a bandwidth limit option, so I'm unsure why you're unable to use it. I suppose I can just SSH into the NAS and search for your rclone mounting command, then try to edit it myself.
thedutchmans
Just to keep you informed, using SSH, I was able to run rclone with the --bwlimit=5M option successfully. This limits the download of OneDrive sync to 40MBps. I'm going to add this request to bandwidth limit rclone to the proper forum.
Thanks for your sharing.
mutexaholic
Post by mutexaholic »
@thedutchmans how did you achieve this?
Return to “CloudSync”
