I'm used to run vlans in docker macvlan on my Synology, after I tried the same config on the F4 SSD my whole unit was unreachable. That might be caused by the missing 8021q module which is not loaded in to the OS these days?
Could you enhance the OS to load this module by default? And / or could I load this module manually to use the vlan tagging in my network, until you embedded it into the OS?
Interestingly the macvlan module is loaded, and currently working fine without vlan tagging.
user@TNAS:~# lsmod | grep vlan
macvlan 28672 0
user@TNAS:~# lsmod | grep 8021q
user@TNAS:~# cat /proc/modules | grep 8021q
user@TNAS:~# modinfo 8021q
modinfo: ERROR: Module 8021q not found.
