[Help] volume corrupt
clonea1
Post by clonea1 »
i am not sure when this happened, i just ran a system update on my f6-424max and a volume is um dead ?
TMnight
Re: [Help] volume corrupt
Post by TMnight »
You may first try the method described in the following link: viewtopic.php?t=2575
If the issue persists, please provide us with a screenshot of the command output for further troubleshooting.
clonea1
Post by clonea1 »
i tried to follow the instructions but i couldnt really figure it out
clone@TERRY:/# btrfs check /dev/mapper/vg1-lv3
Opening filesystem to check...
ERROR: /dev/mapper/vg1-lv3 is currently mounted, use --force if you really intend to check the filesystem
clone@TERRY:/# btrfs check /dev/mapper/vg1-lv2
Checking filesystem on /dev/mapper/vg1-lv2
UUID: cfe6ee30-5987-40fe-b47f-5ebb001ac1fd
[1/7] checking root items
[2/7] checking extents
[3/7] checking free space tree
[4/7] checking fs roots
[5/7] checking only csums items (without verifying data)
[6/7] checking root refs
[7/7] checking quota groups skipped (not enabled on this FS)
found 6588441346048 bytes used, no error found
total csum bytes: 6425656240
total tree bytes: 8569356288
total fs tree bytes: 612892672
total extent tree bytes: 605552640
btree space waste bytes: 891865058
file data blocks allocated: 7223584948224
referenced 7419690835968
After executing the final instruction /etc/tos/scripts/mntdata in the operation guide, does the volume still show as 'damaged'?
If it is still "damaged", please collect the system report zip in the Technical Support-Issues Report collection system, and then send it to our official website Live Chat or support email.
clonea1
Post by clonea1 »
drive still corrupt
log download tool not working
Hmmm… can't reach this page
It looks like the webpage at http://xxxx.local:8181/v2/assistent/dow ... 250831.zip might be having issues, or it may have moved permanently to a new web address.
ERR_INVALID_RESPONSE
i really dont understand those instructions that where provided
You provided a local network link, which cannot be accessed.
Regarding your issue, it is recommended that you schedule an engineer for remote troubleshooting via Live Chat.
