Can we block the access to the web console by the http port to have only https.
Don't find the option
http access to the web console
- sianderson
- Silver Member
Re: http access to the web console
i havent tried it, but under security, there are firewall rules, would denying access to 8181 do the job?
F2-424 TOS 7.0.1140
F2-423 TOS 7.0.1140
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
F2-423 TOS 7.0.1140
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
- JayBlingham
In my opinion, if https is enabled, redirect from http to https should be made to be automatic. This is how most other applications/portals work afaik.
Jay
F5-221 NAS
D5 Hybrid DAS
F5-221 NAS
D5 Hybrid DAS
You could only change the http port but not disable it.
- JayBlingham
Changing the http port is a good option if it can't be completely disabled. It'll still show up in a port-scan, but at least http://<nas-ip-address> won't work.
Jay
F5-221 NAS
D5 Hybrid DAS
F5-221 NAS
D5 Hybrid DAS
