F4-210 USB UPS not detected
Chemic
Post by Chemic »
I have a F4210 with TOS Version 4.1.18 installed. I purchased an APC Back-UPS 700 and plugged the USB cable into one of the rear NAS USB ports.
When I go to Control Panel > General Settings > Hardware & Power > UPS in UPS Information I get "UPS is not connected".
Is there any operation I missed?
sianderson
Re: F4-210 USB UPS not detected
Post by sianderson »
you are quite a few versions behind the current one, so no doubt the response will be to get the unit upgraded to 4.1.31 and see what happens then
F2-424 TOS 7.0.1536
F2-423 TOS 7.0.1536
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
Chemic
Post by Chemic »
I just did it, still the same behavior :cry:
Chemic
Post by Chemic »
After a complete power cycle of both TNAS and UPS and a plug-out/in of the USB cable, the UPS is finally detected.
Problem solved after TOS upgrade!
Return to “System Resources”
