Hi All,
Just purchased a F6-424, and would like to try Unraid on it but I am having trouble booting from the replaced USB. I have seen you need to disable the TOS Boot option and secure boot, but I do not see an option to disable secure boot its always greyed out, did add a bios password no effect. I have also changed the config file on the USB to /syslinux/syslinux.cfg to be: default Unraid OS... no luck!
At the moment I am stuck Help!!!
[Help] Unraid On F6-424
Re: [Help] Unraid On F6-424
The main method of Unraid and TruenasS is the same. You can refer to the following link to reconfigure: https://forums.truenas.com/t/how-to-ins ... -ssd/45105
