The Internet says that computers reboot in 10-30 seconds, computers with an operating system of 10-20 GB.
[Discussion] 3 minute reboot
How can an F8 NVMe device reboot in 3 minutes? How is that possible?
TerraMaster F8, TerraMaster F2-425, Syno 218+
Re: [Discussion] 3 minute reboot
The TOS system is designed to accommodate a wide range of device models. Differences in device hardware lead to varying configuration processes for booting devices, necessitating comprehensive compatibility and adaptation. Consequently, boot times can vary. The device reboot countdown is calculated by averaging the reboot times across a wide range of models to ensure that most devices can boot normally after the countdown ends.
You labelled your post as a "discussion" but it sounds more like the intro to an "argument" - as do many of your posts!
Google search says:
Google search says:
Make of it what you will - I really cannot be bothered.Server boot times can vary significantly, but typically range from a few minutes to over 10 minutes, with some taking even longer. Factors like server size, hardware, and software configurations greatly influence the duration. Smaller servers with minimal plugins and faster hardware may boot in a few minutes, while larger, more complex servers can take considerably longer.
F5-221 TOS7.0.1105 - 4x4TB (Ironwolf) Traid
F2-424 TOS7.0.1105 - 2x500GB nvme (P3) Traid, 2x6TB HDD (HGST) Traid
F2-221 TOS7.0.1105 - 1x3TB Ext4, 1x4TB Btrfs
F2-425+ TOS7.0.1105 - 2x500GB nvme (P3) Traid, 2x6TB HDD (EXOS) Traid
- sianderson
- Silver Member
i would blame mac os for it not letting him access it for 3 minutesGremlin wrote: ↑09 Aug 2025, 18:55 You labelled your post as a "discussion" but it sounds more like the intro to an "argument" - as do many of your posts!
Google search says:Make of it what you will - I really cannot be bothered.Server boot times can vary significantly, but typically range from a few minutes to over 10 minutes, with some taking even longer. Factors like server size, hardware, and software configurations greatly influence the duration. Smaller servers with minimal plugins and faster hardware may boot in a few minutes, while larger, more complex servers can take considerably longer.
F2-424 TOS 7.0.1130
F2-423 TOS 7.0.1130
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
F2-423 TOS 7.0.1130
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
I prefer Burger King, myself.
