[Help] SMB /public share doesn't work on MacOS for Guest
mmalchuk
Post by mmalchuk »
F5-221 6.0.694-00165
MacOS Sequoia 15.5 (24F74)
Guest user can't connect to NAS with Guest permissions.
MacOS didn't show any error just can't connect.
Plain user and admin users can connect and see their homes and public share too.
F5-221 | 7.0.0517 | 10GB RAM | 4x4.00TB Seagate IronWolf TRAID/BTRFS
F4-423 | 6.0.794-01324 | 32GB RAM | 2x512GB NVME System | 4x8.00TB Seagate IronWolf TRAID/BTRFS
Re: [Help] SMB /public share doesn't work on MacOS for Guest
Please check in the Control Panel - Access Permissions - Users whether the guest user is enabled and whether it has the corresponding read and write permissions.
mmalchuk
Post by mmalchuk »
Guest user is enabled and access granted.
The connect button doesn't work and shows no error.
TMbuddy
Post by TMbuddy »
mmalchuk wrote: 03 Aug 2025, 01:05
Please try accessing your TNAS via SMB using an IP connection.
Please also check the permissions of the alluser group. If the permissions of the alluser group are denied, then the guest user's read and write permissions will be invalid.
After inspection, it has been confirmed that this is a defect. We apologize for any inconvenience caused. It will be fixed in future updates.
mmalchuk
Post by mmalchuk »
TMbuddy wrote: 03 Aug 2025, 21:57
There is no problem with DNS nor resolving in SMB.
TMzethar wrote: 04 Aug 2025, 17:18 Please also check the permissions of the alluser group. If the permissions of the alluser group are denied, then the guest user's read and write permissions will be invalid.
An ordinary user from group 'alluser' work well, and admin user too.
Both can access and use their own home folders as well as the /public share.
Please wait for the subsequent TOS version update.
mmalchuk
Post by mmalchuk »
TMzethar wrote: 29 Aug 2025, 04:33 Please wait for the subsequent TOS version update.
F4-423 with 6.0.750 - the same issue. what version we are waiting for?
OrionXie
Saudi Arabia
Post by OrionXie »
mmalchuk wrote: 06 Sep 2025, 20:46
HI
mmalchuk!
The latest TOS6 version available is 6.0.770. Perhaps you could try updating and then attempt again.
have a nice day!
Return to “File Services”
