[Help] Portainer won't start
Discussion about Docker
nomadfromx
Kazakhstan
Post by nomadfromx »
Terramaster F6-474 Max.
For some time now, this bug has been occurring. When going to the Portainer page (http(s)://yournasip/portainer), a redirect to the https://tnas.local:5443/tos/#/desktop web page occurs. Reinstalling Portainer does not help.
Re: [Help] Portainer won't start
Sorry for the inconvenience you have encountered.
It seems you mentioned F6-424 Max.
We have also observed similar issues. They have been fixed in a newer testing version. Please wait for the subsequent updates.
matias
Argentina
Post by matias »
I have a F2-423 and I'm facing the same issue after the upgrade to 6.0.750. :|
Current System
F2-423 - 7.0.0448
12TB storage | 4GB ram
matias wrote: 01 Aug 2025, 02:17
Sorry that you're also experiencing this issue. Please wait for the TOS update after TOS 6.0.750.
A possible temporary workaround: disable and then re-enable Docker Manager.
Return to “Docker”
