TNAS Mobile 3.4.023 bottom navigation menu overlap  [SOLVED]
costinboroda
Romania
Post by costinboroda »
Hello, I am not able to access the bottom navigation menu as the Android navigation buttons bar is overlapping it.
I'm using Android 15 on Sony Xperia 5 V.
Image Image
Re: TNAS Mobile 3.4.023 bottom navigation menu overlap
Sorry for the inconvenience caused. It seems to be a compatibility issue on certain model systems. The project team will check and fix the problem based on your feedback.
TMjack
Post by TMjack »
Hello, our project team has successfully reproduced and verified the issue. Currently, we are actively working on a solution and expect to release a new software package within 1 to 2 weeks to fully resolve the problem. We sincerely appreciate your feedback and support!
SunDogBC
Post by SunDogBC »
When will this be fixed? I get this with version 3.4.042 on Samsung Galaxy S22 on Android 16.
F2-221 - TOS7.0.0403
BIOS/InitBoot version- MAPL0304V17
TNAS mobile (Android) - V3.5.044
crisisacting
Re: TNAS Mobile 3.4.023 bottom navigation menu overlap  [SOLVED]
Post by crisisacting »
SunDogBC wrote: 25 Dec 2025, 15:28
There have been newer versions for the TOS 7 beta which might have the mentioned issue's fix implemented; you'd need to test the most current beta to see if it'll connect/communicate with TOS 6.× builds (it should): https://download3.terra-master.com/Apps ... .5.036.apk
SunDogBC
Post by SunDogBC »
Thanks. I upgraded to TOS 7 beta and the accompanying app update. It is indeed resolved.
tobilo74
Andorra
Post by tobilo74 »
Could you please backport this fix to the application that normal users download from the Android app store?
Having this fixed in a beta app downloaded from terramaster is fine but I would not call this a proper fix.
tobilo74 wrote: 13 Jan 2026, 13:47
Sorry, the test version is not yet suitable for widespread public release.
Please wait for subsequent official version updates.
mdb92154
Pakistan
Post by mdb92154 »
Just from this thread alone, you've had SIX MONTHS to fix this and roll out an update. This is by far the least satisfying answer you could have possibly given. Like, you couldn't have given a worse answer if you tried. So how about making this fix a priority for those of us who have already shelled out money for your equipment so we can properly manage it? You know what the problem is, all that's left is for TerraMaster to just get it done.
Hello, what is your current TNAS Mobile version and phone model? We have released the new TNAS Mobile 3.5.044.
