Transmission is not in the "All apps" list
Transmission, qBittorrent, Aria 2 download applications
AES
Post by AES »
Transmission is not in the "All apps" list. I can't add its shortcut to the home screen.
I also press the "Send to desktop" button, the message "Operation completed" appears, but in fact nothing happens.
TerraMaster F8, TerraMaster F2-425, Syno 218+
TMnight
Re: Transmission is not in the "All apps" list
Post by TMnight »
What is your current TOS version? If it is not the latest, please try upgrading to the latest version, TOS 6.0.750.
AES
Post by AES »
TMnight wrote: ↑12 Jul 2025, 10:46 What is your current TOS version? If it is not the latest, please try upgrading to the latest version, TOS 6.0.750.
I have the latest version of TOS 6.0.750.
Your Transmission might be in a disabled state. Only enabled apps will appear under 'All apps'.
Please enable the Transmission on APP Center.
AES
Post by AES »
In the screenshot above, it says in green on gray that it is on, and this is true. I already know that there is a stupid shutdown that happens by itself and removes shortcuts.
The transmission is on, it works, I use it, it is not on the list.
I don’t remember whether I tried to update it myself to the current version or not, but it is controlled from the app store.
I just turned it off and on, it turned off and on. It did not appear on the list.
MikeZhang
Post by MikeZhang »
AES wrote: ↑15 Jul 2025, 04:02
Please download and install manually
https://we.tl/t-4CWN3XJKVi
AES
Post by AES »
In the application installation window, when selecting a file, the list cannot be sorted by date.
I installed this file, the icon appeared in the list, I was able to pin it to the panel and drop it on the desktop. Thanks.
Return to “Download”
