[Help] Cloudsync with a non amazon s3 service  [SOLVED]
Jmb
Post by Jmb »
Hi, from some posts on this forum I feel that it is possible to configure Cloudsync to work with a non amazon s3 service.
Am I right ?
What is the trick ?
I useTOS6 and Cloudsync 3.2.013.
Any help apreciated, thank you in advance.
JM
Re: [Help] Cloudsync with a non amazon s3 service
In addition to Amazon S3, we have also integrated other cloud service providers in CloudSync for connection.
Jmb
Post by Jmb »
Thank you for your answer.
I've seen that Cloudsync propose other services. I've been successful using google drive. However, I need to use a S3 service that I subscribed to but I don't find it in the list (it is called N0c storage).
Is there a way to create a connexion with such a service ?
I'm able to generate a valid .conf file from Rclone to this servive for instance.
Any Cloudsync .conf file I can edit ?
Re: [Help] Cloudsync with a non amazon s3 service  [SOLVED]
You can choose the S3 protocol at the bottom of the cloud service provider list and manually add other S3 protocol providers.
Jmb
Post by Jmb »
Thank you very much !
I made my first tests from my android tablet and was not able to scrolldown the listbix at the full bottom.
I did it from my PC and was able to see and select the S3 protocol option !
Many thanks for your patience and your excellent answer.
JM
Return to “CloudSync”
