[Help] Using hardware encoding for a Jellyfin Docker install on a F4-424 Pro
Discussion about Docker
bartmans99
Netherlands
Post by bartmans99 »
I can't get hardware encoding working on a Docker install of Jellyfin. Turning hardware encoding on gives an error when playing files.
I have it working on Emby but would prefer Jellyfin. Not to keen on using the TOS apps, I'm used to Docker.
Does anybody have this working on a F4-424 Pro?
bartmans99
Netherlands
Re: [Help] Using hardware encoding for a Jellyfin Docker install on a F4-424 Pro
Got it working by adding GIDLIST: 937 to the compose.
environment:
TZ: Europe/Amsterdam
UID: 1007
GID: 1007
GIDLIST: 937
The command /usr/lib/jellyfin-ffmpeg/vainfo now confirms that VA-API is active.
TerraMaster could be maybe look at a correct way for Docker container to run as non-root.
Return to “Docker”
