Mouse not aligned in windows remote desktop
vichi95
Post by vichi95 »
whei i try to connect at my virtual machine (windows 7), my local and remote cursor are not aligned. How can i fix?
Re: Mouse not aligned in windows remote desktop
VBOX's compatibility with windows, this cannot be solved temporarily. You can turn on the remote function of windows in the virtual machine, and then access through remote access.
vichi95
Post by vichi95 »
Not run anyway, this problem is only on windows VM. But, is a bug?
Not so sure what's the cause there. You could contact support(at)terra-master.com to get more help.
vichi95 wrote: ↑02 Oct 2020, 15:45 Not run anyway, this problem is only on windows VM. But, is a bug?
I have seen quite a lot similar reports on virtualbox forum, you can report it to virtualbox.org and ask for help.
vichi95
Post by vichi95 »
Hi, i've RESOLVED the issue by asking on the virtualbox.org forum:
https://forums.virtualbox.org/viewtopic ... 09#p486509
Procedure:
- Guest Virtualbox window, Devices Menu, Insert Guest Additions CD Image, run the installer in the guest's CD drive, if not work, after downloading the imgage, copy it into this path:
usr/share/virtualbox/
- Rename file.iso as following: VBoxGuestAdditions.iso
- Update and run.
ENJOY :D
Great to know it, and thank you for your sharing.
Return to “Network”
