[Help] Creating directory and file transfer issues TNAS F423
simoncc
Italy
Post by simoncc »
Hi all,
I'm a new user of TNAS devices , used QNAP till now.
I use a Mac to connect to TNAS ( 2.5gps ethernet cabled connection) with a Raid 1 7200rpm data disks , and a 512GB NVME cache disk .
I have 2 issues :
1) Lately I suddenly started to have issues creating and deleting folders on my TNAS smb share.
If I create a new directory I cannot set the name, it is always named "untitled folder" and it is not writeable or readable for insufficient permissions. I can delete only using TNAS local terminal ( via ssh, or using webui ).
Tried several solutions without finding one. same share with Wndows PC no issues. Maybe latest Sequoia update introduced some issues ? I opened a Terramaster support ticket and no solution proposed yet.
UPDATE: with latest TNAS 6 update , initially the issue was there but after some hours it seems to work , will update on this
2) When transferring big files , that is the main activity that I do, transfer speed is great, but when it passes to the next file it pauses for like 10 seconds at 0 Kb/s and after that starts at full speed
any ideas or anyone with the same issue ?
S
MikeZhang
Re: [Help] Creating directory and file transfer issues TNAS F423
Post by MikeZhang »
simoncc wrote: ↑20 Jun 2025, 23:47
Sorry for the inconvenience, please generate system log and send to our engieer to check for you support at terra-master.com
simoncc
Italy
Post by simoncc »
MikeZhang wrote: ↑21 Jun 2025, 08:09
I already opened a ticket more than a month ago but still I don'0t have received any solution, only a statement that Terramaster is working on it. Is it a known bug ?
TMbuddy
Post by TMbuddy »
simoncc wrote: ↑29 Jun 2025, 03:06
We sincerely apologize for the delayed response.
Could you please confirm your email address so we may verify the current status and provide you with an update on the issue resolution?
Return to “File Services”
