[Help] access shared folder remotely
servit00
Italy
Post by servit00 »
hello everyone. i installed tnas and shared the folder. i can connect remotely too. my need is to create a real connection on file explorer to be able to easily use shared files remotely quickly. i didn't succeed, i don't know where to start, do i have to open ports on the fritzbox? do i have to activate something on the nas? or is what i'm asking not feasible? thanks
TMeric
Re: [Help] access shared folder remotely
Post by TMeric »
Hello, if your NAS network has a public IP, you can try enabling the WebDAV or FTP feature in the NAS file services and configure the corresponding port forwarding on the router. Then, you can use software like RaidDrive on the remote computer to map the remote shared folder to your computer. Hope this helps!
Return to “Network”
