[Help] sync from android phone to f2-212
Hello. Please what is the simply way? I would like upload folder in android phone to a folder in nas. What are apps ti download in phone and in terramaster? Thanks
Re: [Help] sync from android phone to f2-212
You can use either of the following two methods: 1. Access the NAS device via File Management - Network Neighbors (SMB) and upload files; 2. Use third-party apps such as ES File Explorer to upload files.
Which application are you referring to TI? I'm unsure which software you're asking about, so please provide a detailed description or a screenshot.
Thank yiu for help. I was trying for a sync software, not a manual upload. Is it impossible?OrionXie wrote: ↑10 Jun 2025, 17:09You can use either of the following two methods: 1. Access the NAS device via File Management - Network Neighbors (SMB) and upload files; 2. Use third-party apps such as ES File Explorer to upload files.
Sorry, the TNAS system does not have a built-in dedicated application or function for directly synchronizing mobile phone folders, but your requirements have been recorded in detail and entered the requirements review process. We will continue to pay attention to users' demands for mobile data synchronization scenarios.
As a temporary solution, you can deploy third-party synchronization tools (such as Resilio Sync, Syncthing, etc.) through the Docker function of TNAS to achieve cross-device folder synchronization.
