[Help]F8 SSD Plus: Certificate Error When Reverse Proxy Into TOS UI (TOS v6.0.650))
- JDB321Sailor
When accessing the Terramaster UI from a reverse proxy the TOS will auto redirect all traffic to the IP address it is currently assigned. The issue, is if you have a certificate from an official source, upload the certificate to TOS and then route traffic to TOS through the reverse proxy, the redirect from the reverse proxy DNS record to the IP address causes the web browser to have a warning, dangerous condition due to the mismatch certificate and address. TOS has the official certificate from a trusted source (i.e. Lets Encrypt) for say tos.example.com, but the auto change to 192.168.1.5 assigned IP causes the mismatch. There is no way to change this IP address in the settings within TOS. I am requesting a way to change the default DNS address TOS redirects to, to a custom DNS address, so the address of the certificate matches TOS address and I don't have to use a self signed certificate. The self signed certificate causes the same distrust problem as a mismatched certificate, so that is not a good solution either. A trusted source certificate is better all around.
