I've just bought a D5-Thunderbolt 3 DAS and have 4 x Seagate Ironwolf 6TB to install.
Is it possible to add an SSD as the 5th drive ? I'd probably use it for speed/scratch disk for editing, and keep the 4 HDD as a RAID 0 or 10 - is it possible to mix them ? Or for the SSD to be used as a caching drive ?
Mixing SSD and HDD
claudiocarli
Re: Mixing SSD and HDD
I have just added a 500Gb SSD to the 5th slot. To set it as ssd cache must now go to other volumes, click edit and set ssd cache?
I have some data on them which I won't lost...
Thank you
Thank you
claudiocarli
My ssd is new. It can be formatted. My concern is if the hard drive with data is also formatted.
I am looking to do the same thing with my SSD. Does it have to be in the 5th slot. i can not see any option i have it in the 4th slot.
Hi, everybody.
D5 Thunderbolt 3 do not support SSD Cache.
