[Help] UPDATE CHECK FAILED
xyzzzzz
Philippines
Post by xyzzzzz »
I am encountering this issue again regarding my device. (see image attached)
I have previously encountered this issue when I was about to check for updates for my F2-423 and the only solution I thought of was to reset it and initialize the device again.
I have no idea what's causing this problem.
Hope someone helps.
Thanks!
TMnight
Re: [Help] UPDATE CHECK FAILED
Post by TMnight »
xyzzzzz wrote: 03 May 2025, 19:06
It seems that the problem is because the NAS has no WAN connection. I have replied to you via email. Is the problem solved now?
Return to “System Update”
