[Help] Getting prompt to Select Certificate
TechExplorer
Japan
Post by TechExplorer »
Please help.
I am mapping a shared folder and got prompted to select certificate. What is this for? Where this certificfate come from?
EthanLiu
Re: [Help] Getting prompt to Select Certificate
Post by EthanLiu »
TechExplorer wrote: ↑01 May 2025, 22:15
Under normal circumstances, when connecting a device via SMB, there is no requirement to select a certificate. You need to verify whether the option to select a certificate stems from the configuration of another application rather than being a choice for mounting an SMB network drive. Additionally, you should confirm whether you have enabled any other services, such as a reverse proxy.
TechExplorer
Japan
I haven't enabled any other services. Only SMB and SSH are enabled. I also have not install any other application recently, just Windows update.
TMjack
Post by TMjack »
Hello, please uncheck the option "Connect using different credentials" and try logging in with only the password of your domain account.
Kevin
Post by Kevin »
https://learn.microsoft.com/en-us/windo ... oup-policy
Hey, check out this guide titled "Configure the SMB Client to Require Encryption in Windows" — it might help you determine whether your Group Policy settings are correct or if you're missing the required policy templates (ADMX). Let me know if it matches your issue.
Kevin
Post by Kevin »
SMB signing
Starting with Windows 11 24H2 and Windows Server 2025, all outbound and inbound SMB connections are now required to be signed by default.
Return to “Privileges”
