Update to 6.0.673, broke Qbittorrent
WhitePastor
Armenia
Post by WhitePastor »
After the update i get nginx 502 error on the qbittorrent page.
Haven't applied any changes the default ports are 8181 and 5443.
Any ideas?
Lol Signatures still exist,
TERRAMASTER F2-423, 12 GB Ram
2X 8TB Segate Iron Wolf ST8000VNZ04/N004 (RAID1)
2x Western Digital 500GB WD Red SN700 NVMe (RAID1 for Caching)
Maybe I will put something meaningful here later ;)
OrionXie
Saudi Arabia
Re: Update to 6.0.673, broke Qbittorrent
Post by OrionXie »
WhitePastor wrote: ↑30 Apr 2025, 04:46
Perhaps you can try uninstalling the qbittorrent application, deleting the qbittorrent shared folder, and reinstalling the application. Can you provide the specific version of the TOS system before the upgrade? thank you.
WhitePastor
Armenia
I tried clean installation, uninstalling configs same...
I keep up to date with TOS6
TMeric
Post by TMeric »
WhitePastor wrote: ↑30 Apr 2025, 22:23 I tried clean installation, uninstalling configs same...
You can try reinstalling qBittorrent by following these steps:
1.Uninstall the current version of qBittorrent: First, uninstall the existing version of qBittorrent and choose to remove all configuration files during the uninstallation process.
2.Delete the qBittorrent shared folder: Go to the Control Panel and find and delete the qBittorrent shared folder. If there are important files in that folder, be sure to transfer them to another location beforehand.
3.Reinstall qBittorrent: After completing the above steps, you can reinstall qBittorrent from the application center.
hope this can help you.
danx
Japan
Re: 6.0.673に更新し、Qbittorrentを壊した
Post by danx »
私も 6.0.73にアップデート後qBittorrentのバージョンを4.1.15にアップデートしたら、
qBitotorrentを立ち上げたところ502エラーが出るようになりました
ダウンロードリストをやtorrentファイルを消すことがなくリカバリーをすることを望んでいます。
初期化やアンインストールをせずに復旧できればと思います
After updating to 6.0.73, I also updated the version of qBittorrent to 4.1.15,
When I started qBitotorrent, I started to get a 502 error.
I hope to recover without erasing the download list or torrent files.
I hope I can recover it without initializing or uninstalling it.
TMeric
Post by TMeric »
You can also check if the qBittorrent application user has read and write permissions for the qBittorrent shared folder. It’s possible that the permissions were lost during the upgrade process. The steps are shown in the image below:
WhitePastor
Armenia
Well I ended up restarting to factory settings as I couldn't find anything wrong in the bitorrent service config...
But now works, thanks for support guys
Return to “System Update”
