Surveillance Live View not showing RTSP cameras, only ONVIF  [Accepted]
A CCTV monitoring and recording application
SprintST
Post by SprintST »
Hello all. Brand new to Terramaster, coming from a couple Synology units
New F6-424 Max, TOS 6.0.673, 64gb memory, NVME and spinners
All (4) cameras work fine during setup and show a preview.
All (4) cameras are recording and I can view the files
Only the ONVIF camera shows a Live feed, the RTSP cameras do not.
Local area net connection
Setup a firewall rule to allow ports 80 and 554 to pass signal, should be good there, since it's recording a valid video
Resolution is set to 1280x720 on all (3) RTSP cameras
Resolution is set to 2560x1440 on the ONVIF
Thoughts? Solutions?
Thanks all
MikeZhang
Re: Surveillance Live View not showing RTSP cameras, only ONVIF
Post by MikeZhang »
Hi, what are your RTSP cameras models?
Return to “Surveillance Manager”
