[Help] Where is the Bond menu ?
GodefroydeMaupeou
France
Post by GodefroydeMaupeou »
J'ai connecté les deux ports Lan de mon Mac Pro 2019 sur mon 12D 500 Pro avec TOS 6 mais je ne vois pas le menu pour créer un bond ?
Le + en haut à droite est en grisé.
Re: [Help] Where is the Bond menu ?
GodefroydeMaupeou wrote: ↑25 Apr 2025, 16:05 J'ai connecté les deux ports Lan de mon Mac Pro 2019 sur mon 12D 500 Pro
Pourquoi?
The conditions do not seem to be met. Although the two IP addresses you set are similar, your Mac Pro 2019 also needs to have switch functionality. In reality, the NAS is merely connected to the network cards of the Mac with similar IP segments.
TMzethar wrote: ↑25 Apr 2025, 19:07
Actually, I was going to guess that nas IP addresses have not been set at all. The IP's returned look much like the defaults set when nas is set as DHCP client and there is no DHCP server on the segment.
Return to “Network”
