[Help] In the TOS web interface, sorting by file date or name does not work in principle
AES
Post by AES »
In the TOS web interface, sorting by file date or name does not work in principle.
Here the files are sorted by name:
Here the files are sorted by date:
:x
TerraMaster F8, TerraMaster F2-425, Syno 218+
Re: [Help] In the TOS web interface, sorting by file date or name does not work in principle
In your example the date-sort appears to be alphanumeric on the displayed date.
TMeric
Post by TMeric »
AES wrote: 05 Apr 2025, 23:27 In the TOS web interface, sorting by file date or name does not work in principle.
:x
Thank you for your feedback. There are indeed some issues with the name sorting, and our team is working on fixing them. Regarding the date sorting, you can change the date format to yyyy.mm.dd in Control Panel > Region and Language > Time. This format works without any issues.
AES
Post by AES »
I use this type of date, I am not used to it any other way.
TMeric
Post by TMeric »
AES wrote: 06 Apr 2025, 10:46 I use this type of date, I am not used to it any other way.
Sorry for the inconvenience caused. I have already reported this issue to the relevant department for resolution.
Return to “File Services”
