File exclusion list - wildcards
TFM Backup is the abbreviation of TerraMaster Folder Mirror backup. TFM Backup is a dedicated backup tool for TNAS shared folders developed by TerraMaster.
darkmakers
Australia
Post by darkmakers »
Anyone have any idea if its possible to use wildcards in the file filter of items to exclude? Im trying to ignore any sub folders and files inside any folder named 'node_modules'. I've tried **/node_modules/** but it doesnt do anything.
Thanks.
TMlinda
Re: File exclusion list - wildcards
Post by TMlinda »
darkmakers wrote: 04 Apr 2025, 07:05
Are you operating in the TFM Backup application interface? Can you provide a screenshot?
GevinKe
Post by GevinKe »
We regret to inform you that wildcard filtering is currently not supported. At this time, the TFM only allows filtering based on file extensions.
However, we do have plans to optimize the file selection strategy in future updates, and the new approach will be designed to easily accommodate your requirements.
Return to “TFM Backup”
