F210 no access to files
bigmac747
Post by bigmac747 »
setup F2-210
TNAS-PC can see the file folders but I cannot access the files.
TOS stopped displaying the file structure in browser.
Resource monitor shows CPU 10% but total memory in use 94.28%
Network check shows that PING Packet loss is 27% tested 20 feet from NAS
Can I remove the 2 drives [2x 4TB WD] and run the factory reset
Will my drives be able to be read after the reset?
Re: F210 no access to files
Return to “Initialization”
