(Guide)TerraMaster Docker Manager Jellyfin hardware transcodeing enabled
Guides created and maintained by community members, not official documentation.
EthanBerg97
Norway
Post by EthanBerg97 »
Hello quick guide on how to enable the transcodeing on jellyfin and setup jellyfin on TOS.
if you do not know how to find the Volumes and directory all you have to do is open file manager and right click and click property it will then say the location you need to enter in the YAML file :)
services:
jellyfin:
image: lscr.io/linuxserver/jellyfin:latest
container_name: jellyfin
environment:
PUID=0
PGID=0
TZ=UTC+01:00
JELLYFIN_PublishedServerUrl=http://192.168.*.*
DOCKER_MODS=linuxserver/mods:jellyfin-opencl-intel
volumes:
/Volume1/public/jellyfin/config:/config
/Volume1/tvshows:/data/tvshows
/Volume1/movies:/data/movies
devices:
/dev/dri:/dev/dri
ports:
8096:8096
8920:8920
7359:7359/udp
1900:1900/udp
restart: unless-stopped
Here are the steps for your reference.
RayKah
Singapore
Re: (Guide)TerraMaster Docker Manager Jellyfin hardware transcodeing enabled
Post by RayKah »
Thank you, this is helpful. I usually use Plex, I will try to set the Jellfin too.
EthanBerg97 wrote: ↑30 Mar 2025, 22:24
That's great!
GDragon
Poland
Post by GDragon »
very interesting, but how can I setup jellyfin on Docker?
XtinaLover
France
Post by XtinaLover »
Je vous recommande Plex, est-ce que cela vous serait utile ?
F8 SSD Plus; 6.0.610; 2 x 1024G KC3000 PCIe 4.0 SSD;
:idea: Dans l'ocean des données, le stockage est mon bateau.
sergio
Germany
Post by sergio »
The Jellyfin should download from the community, right?
HeliaWu
Post by HeliaWu »
sergio wrote: ↑03 Apr 2025, 18:04 The Jellyfin should download from the community, right?
The Jellyfin application is available both in the Community Apps and the TNAS system's App Center. However, there might be slight differences in usage methods depending on the source from which the application was downloaded.
Frostbyte
Post by Frostbyte »
Exactly what I needed. Appreciate the clear steps!
Peterlll06
Netherlands
Post by Peterlll06 »
Thanks! Love the community vibe here!
RayKah
Singapore
Post by RayKah »
The Plex price has increased, so maybe I will use Jellyfish more. :)
Return to “Community-Created Guides”
