Hi!
I want to purchase an f6-424 and I need to understand if it supports this SEAGATE Exos X20 enterprise ST20000NM007D 3.5" 20.0Tb SATA 6Gb/s 7200rpm 256MB HDD.
There is no such drive in the list of compatible HDDs, so I want to clarify if someone has installed this HDD in the NAS.
Link to the list of compatible HDDs https://www.terra-master.com/global/compatibility/
[Help] f6-424 supported hdd
- AnsleyRempel
Re: [Help] f6-424 supported hdd
If you need it now, please contact me directly at 02515751236.
- Peterlll06
I suggest you use a hhd from the compatible list to avoid compatibility issues.
