Hey again
Another , I am sure is a silly, problem.
F4 423
I have two drives set in single disk set up and I have media files to go onto them, video on one, music on the other.
But how do I choose where they go?
File Manager does not appear to show me which drive a folder I create will be?
Any help would be great (again)
Many thanks (again)
[Help] Two drives set in single disk set up but...... [SOLVED]
Re: [Help] Two drives set in single disk set up but...... [SOLVED]
Solved by myself
You need to create a shared folder yourself - NOT share a standard folder you previously created.
When you create a shared folder you can select which volume the folder will reside. So then you have a destination where to put your incoming media etc
Yay
Yay
