Hi
I want to add a spare drive but TOS warns that all data will be deleted. Is that true ? Why ?
Adding a Spare Drive deletes all data ?!?
Terramaster F4-210
- sianderson
- Silver Member
Re: Adding a Spare Drive deletes all data ?!?
On the new drive yes and because it needs to format it into the correct file system
Your original drive shouldn’t be affected, it can convert your single disk to a raid array without losing data on the first drive
F2-424 TOS 7.0.1298
F2-423 TOS 7.0.1298
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
F2-423 TOS 7.0.1298
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
"shouldn’t" sounds not good. I have to be sure because I can't save the data to another drive,
Terramaster F4-210
TOS says hard drives (plural !) and not "data on the new hard drive will be deleted". So for my understanding data on ALL hard drives will be deleted.
Terramaster F4-210
When you got this prompt what action were you processing? If you were creating a new storage pool and new volume on the drive, then you must know which drive you were operating.
All drives you insert into your tnas will be formatted to ext 4 or btrfs file system, your data on the drive will be erased.
This is a huge problem. Is this always the case or only with Terramaster ?
And what happens when I add the fourth harddrive to the existing RAID5 ? Do I also loose a data ?
Terramaster F4-210
Then you only lose data on the forth drive, not the raid 5.
Ok, I'm doing this right now.
And seriously ... I hope this is a joke (1000 hours to synchronise ?!?):
Terramaster F4-210
