Centralized Backup 3.0.139 (X86) Update Notification
Centralized Backup is a professional disaster recovery tool specially developed for business users.
GevinKe
Post by GevinKe »
TOS Applicable Versions:
TOS 6.0, TOS 5.1.
Important Notice:
This version of Centralized Backup has undergone a major refactoring of the FileServer module, bringing a comprehensive upgrade to its functionality. Due to the significant changes, task data from the previous version is no longer compatible with the new version. After updating, you may experience task information loss; however, your previously backed-up data will remain unaffected. You can continue protecting your data by recreating tasks.
If you choose to continue using the old version 3.0.090 and wish to retain your current tasks, please do not click the "Update" button. We sincerely appreciate your understanding and support. Your user experience remains our top priority.
Version Update Notes:
1. Optimized certain interface designs and instructional prompts.
2. Refactored the FileServer module.
3. Added task import functionality for computers, physical servers, and file servers.
4. Introduced computer sleep control.
5. Added batch management for devices and tasks.
6. Added domain distribution support for CBA.
7. Introduced CBA version detection and automatic update functionality.
8. Added local network IP search for CBA.
9. Added Debug log export for CB/CBA.
10. Fixed issues with incremental backup.
11. Resolved various known issues.
Explanation:
Since older versions of Centralized Backup Agent (version 3.0.065 and earlier) do not support automatic updates, the update process may fail. We recommend manually downloading and installing the latest client. From future versions onward, updates can be performed directly in the Centralized Backup device management section.
Update Method:
Go to TOS > App Center > Search for Centralized Backup > Click "Update".
Return to “Centralized Backup”
