qBittorrent does not enable the app with TOS 6.0.650
Transmission, qBittorrent, Aria 2 download applications
danx
Japan
Post by danx »
qBittorrent が TOS 6.0.650でアプリが有効になりません
ずっと有効化の画面のままで止まっています
なんとかqBittorrentを動かしたいのですがqBittorrentのアプリをTOS 6.0.650で有効にしてください
It has been stuck on the activation screen for a long time.
I want to run qBittorrent somehow, but please enable the qBittorrent app with TOS 6.0.650
Re: qBittorrent does not enable the app with TOS 6.0.650
No similar situation has been observed. The issue should be unrelated to the system and the qBittorrent app. It is recommended that you generate and download the log report package in TOS > Technical Support > Report Issues, and then send it to Support Team for inspection.
Return to “Download”
