TOS 4.1.30 wont install on new F4-220 initialisation
Rhonlith
Post by Rhonlith »
Hi I've just tried to setup a new F4-220 out off the box and couldn't get TOS 4.1.30,
TOS 4.1.30 Installation has failed restart you NAS
Restarted NAS
Restarted NAS
Shutdown NAS, plugged hard drives into a Windows PC, cleared all the volumes and formatted the drives
Restarted NAS
Restarted NAS
Downloaded TOS 4.1.27 instead, everything has worked.
Anyone else had issues with TOS 4.1.30 on a new NAS setup?
Tricky
Re: TOS 4.1.30 wont install on new F4-220 initialisation
Post by Tricky »
Try re downloading the update as the first you downloaded could be corrupted.
May I know how the 4.1.30 update failed? it failed at which step? do you have a screenshot?
Return to “Initialization”
