[Unpackerr] Automated Archive Extractions
About: https://unpackerr.zip/
Category:
Applicable TOS6: 6.0.124 or later versions
App download: https://tmnascommunity.eu/download/Unpackerr
TOS5 & TOS6: click on Support & Help from app description inside the App Center
About:
Unpackerr is an application that runs on Windows, macOS, Linux, FreeBSD and in Docker. You can use it to watch a download folder and extract new items. The more common use is to watch starr apps (radarr, sonarr, readarr, lidarr, whisparr) and extract items they download. It can do both, at the same time even.
Features
Simple to use.
Rich logs.
Extracts entire folders.
Extracts your subs files too.
Cleans up extracted items.
Can extract in place or somewhere else.
Can execute scripts/commands based on extraction events.
Can send webhooks based on extraction events.
Provides a metrics endpoint for Prometheus scraping.
Has a nifty Grafana dashboard to visualize what it did.
Description
This application runs as a daemon on your download host. It checks for completed downloads and extracts them so Lidarr, Radarr, Readarr, and Sonarr may import them. There are a handful of options out there for extracting and deleting files after your client downloads them. I just didn't care for any of them, so I wrote my own. I wanted a small single-binary with reasonable logging that can extract downloaded archives and clean up the mess after they've been imported.
Not a starr app user, and just need to extract files? We do that too. This application can run standalone and extract files found in a "watch" folder. In other words, you can configure this application to watch your download folder, and it will happily extract everything you download. This has nothing to do with the four Starr apps mentioned in the previous paragraph. This Folder-watch feature may be used with or without Starr apps.
Archives Supported
Pretty much everything. It also extracts recursively, meaning deep within folders, and archives within archives. Tars, Rars, Zips, 7-Zips, Gzips, Tarred gzips and bzips; encrypted rars and 7zips. And ISO disc images. Need something else? Ask. Does it do too much? Let me know what knobs you need. Open a request!
Unpackerr will decompress archives of these types:
rar, tar, tgz, gz, zip, 7z, bz2, tbz2, iso
Multi-file archives are supported with RAR and 7ZIP formats.
Password protected archives are supported with RAR and 7ZIP formats.
Archives are detected by the file extension. ISO is disabled by default.
