iSCSI Target error
Discussion about iSCSI Target.
alan
iSCSI Target error
Post by alan »
Hi. I updated my F2-220 to the latest version of TOS (4.1.30), and now I get the attached error when trying to access the iSCSI Target config of the Control Panel. Any ideas?
Re: iSCSI Target error
As your tos has been update a lot from your original version, so you need to uninstall the old version and install a new one.
alan
Post by alan »
Really? I followed the exact instructions to update every step of the way :(
alan
Post by alan »
How do I take care of that? By uploading the installataion package the same way as the Software Updates?
You only need to uninstall the app and install it again.
alan
Post by alan »
Hi. It's the Control Panel. How do I go about doing that?
So this happened when you tried to click the "Virtual Disk" on control panel, right?
would you try following solution?
1. download the 4.1.30 installation package http://dl.terra-master.com/cn/TOS_S2.0_ ... 061157.ins
2. Reinstall your 4.1.30 again by following instruction:viewtopic.php?f=75&t=423
alan
Post by alan »
> "So this happened when you tried to click the "Virtual Disk" on control panel, right?"
Hi. No. Please check out the screenshot in the first post.
@alan
I did see it, but I didn’t understand how this prompt come out. I need your input please.
alan
Post by alan »
Sure: Open "Control Panel", search for "SCSI".
Return to “iSCSI Target”
