Hey everyone,
I just set up my F6-424 Max with two 20TB drives in TRAID, but the storage pool initialization is crawling—after 24 hours, it's only at 0.01% (2.63GB/20TB).
Is this normal? Has anyone else experienced such slow initialization times? Any tips to speed things up?
[Help] F6-424 Max Storage Pool Initialization Extremely Slow? [SOLVED]
- CodeHunter
Re: [Help] F6-424 Max Storage Pool Initialization Extremely Slow?
This progress is abnormal. We recommend that you generate and download the log report package in TOS > Technical Support > Report Issues, and then send it to technical team for inspection.
This is a repeated post. Just because of display the widget , @codeHunter misunderstood the process. we will optimize this view of display in the future version.
- RaymondBarton
The initialization of a storage pool in TRAID can take a long time, especially when the disk capacity is very large, as in your case 20TB. However, an initialization speed of only 0.01% after 24 hours may be unusual, as this process should normally be faster. Please contact support to resolve this issue.tunnel rush
