Any updates on the software for MacOS14 or higher.
Did not see that TerraMaster was not compatible with the new Mac operation system.
Don't want to install Windows Parallels.
TerraMaster RAID Manager for Mac OS14
Re: TerraMaster RAID Manager for Mac OS14
Hello. Are you using D5-300?
There is currently no update for RAID Manager available for newer versions of macOS.
At present, it is only possible to observe, create, and rebuild RAID for D5-300 through Windows or older versions of macOS.
- crisisacting
- Silver Member
You can also run a virtual Windows OS on your Mac to set up the RAID first - it works as well. Here’s one option for reference: https://www.parallels.com/products/desktop/
