Logging?  [SOLVED]
rfbjr
Logging?
Post by rfbjr »
I saw a locked topic from 2021, but the question is still the same:
I have TNAS.online setup and active for TerraMaster support, is there any logging/email notification when someone connects via TNAS.online? If not I think there should be at least for audit trails.
F4-424 Pro (x2) and F4-425 Plus at 7.0.1536
F6-424 Plus at 7.1ß
D4-320 & D4-SSD
Re: Logging?
Which post are you referring to? (Link?)
On version 6.0.648 that you are using, you can view this information under TOS > Control Panel > System Logs > HTTP.
rfbjr
Re: Logging?  [SOLVED]
Post by rfbjr »
Yes thanks I saw that after my post. Well remembered it was there actually.
F6-424 Plus at 7.1ß
D4-320 & D4-SSD
Return to “Network”
