[ Dex ] A Federated OpenID Connect Provider
About:
Category:
Applicable TOS6: 6.0.420 or later versions
App download: https://tmnascommunity.eu/download/Dex
TOS5 & TOS6: click on Support & Help from app description inside the App Center
About:
Dex supports a wide range of identity providers such as LDAP, SAML, and OAuth2 and implements OpenID Connect (OIDC), allowing your application to plug in any upstream identity provider, but implement only OIDC.
Whether you’re looking to secure your internal applications, provide seamless Single Sign-On (SSO) across your organization, or create a secure public-facing platform, Dex can be tailored to meet your unique requirements.
