[ Oauth2Proxy ] A reverse proxy and static file server
About: https://oauth2-proxy.github.io/oauth2-proxy
Category:
Applicable TOS6: 6.0.420 or later versions
App download: https://tmnascommunity.eu/download/Oauth2Proxy
Required packages:
TOS4: http(s)://yournasip:port/modules/pgAdminOKM/www
TOS5 & TOS6: click on Support & Help from app description inside the App Center
After installation, you must configure one of the OAuth providers.
Valid providers are :
ADFS
Bitbucket
DigitalOcean
Facebook
Gitea
GitHub
GitLab
Google default
Keycloak (Deprecated)
Keycloak OIDC
LinkedIn
login.gov
Microsoft Azure (Deprecated)
Microsoft Entra ID
Nextcloud
OpenID Connect
More info on https://oauth2-proxy.github.io/oauth2-p ... providers/
About:
OAuth2-Proxy is a flexible, open-source tool that can act as either a standalone reverse proxy or a middleware component integrated into existing reverse proxy or load balancer setups. It provides a simple and secure way to protect your web applications with OAuth2 / OIDC authentication. As a reverse proxy, it intercepts requests to your application and redirects users to an OAuth2 provider for authentication. As a middleware, it can be seamlessly integrated into your existing infrastructure to handle authentication for multiple applications.
OAuth2-Proxy supports a lot of OAuth2 as well as OIDC providers. Either through a generic OIDC client or a specific implementation for Google, Microsoft Entra ID, GitHub, login.gov and others. Through specialised provider implementations oauth2-proxy can extract more details about the user like preferred usernames and groups. Those details can then be forwarded as HTTP headers to your upstream applications.
