There seems to be an issue with port conflicts with the latest TOS 6.0 and the latest version of Emby.
When Emby is installed the link it creates in the Applications list has the port # of the TerraMaster TOS Admin. Emby uses a different port. This creates a conflict of ports and if you attempt to try and activate Emby's Premiere key you are not able to do so.
The only solution currently is to manually set your own shortcut link using the correct Emby port. Using the Emby link created in TOS from All Applications will not work correctly.
Emby devs have said the issue lies on TerraMaster end.
Emby Fails to Load Due to Port Conflict
Re: Emby Fails to Load Due to Port Conflict
Have you installed the Jellyfin application? There is indeed a port conflict issue between the two. To ensure proper functionality, you must manually modify the port of one of them.terroradagio wrote: ↑23 Feb 2025, 13:51 There seems to be an issue with port conflicts with the latest TOS 6.0 and the latest version of Emby.
- terroradagio
Only Emby has been installed.
You can open TOS > All Applications > Terminal and enter the following command to confirm if the port is also being used by any other processes.
netstat -p |grep 8096To contact our team, please send email to following addresses, remember to replace (at) with @:
- terroradagio
It is only being used by Emby
Can you provide some screenshots of this anomaly? We need more information about the situation.
