Mediadb service location
Pulsar
Post by Pulsar »
Hello!
I found that HDD's in my NAS make some noise when I'm definitely not using them..
After some investigation, I found this unexpected activity:
CW /Volume1/@system/media/pgsql/*
So, there's a media service that uses postgres and a service directory is created on Volume1, which is accessed every few seconds.
The disks do not go to sleep.
mediadb.service
/usr/lib/postgresql/13/bin/postgres -D /Volume1/@system/media/pgsql
I'm trying to figure out how to move this directory to another Volume2, or where the configuration is located, in which a specific startup path is specified.
If anyone has encountered such a problem, I would appreciate any advice!
charlesharrel
Re: Mediadb service location
Post by charlesharrel »
I think you should check the service configuration for mediadb.service. You can usually find the configuration file in /etc/systemd/system/ or /lib/systemd/system/. Use the following command to view the contents:
cat /etc/systemd/system/mediadb.service
Look for lines that specify the ExecStart command or any paths related to the database directory.
rvescovi
Italy
Post by rvescovi »
I discovered same issues, my hdd (Volume2) never went in sleep from long time, because there are continue changes on:
/Volume2/@zlog
/Volume2/@system/media/pgsql
.bash_history file -> just in case I will logged in
I found that the media configuration is located here:
cat /etc/default/mediadb
database=/Volume2/@system/media/pgsql
So it's pretty easy to change manually but after a reboot the system is reverted to old Volume2, so how did you proceed safely and permanently?
Pulsar
Post by Pulsar »
well, will try to set the config file to readonly permission
