Cloud Sync is not in my app store
leaponover
Korea South
Post by leaponover »
I am trying to sync Google drive with my Terramaster F2-210.
There's no cloud sync in the app store. Only something called pCloud. When I try to use the Google Drive Sync, the only folders I'm allowed to choose from in create are the appdata folder and the public folder. I don't have access to anything else. Please advise.
Re: Cloud Sync is not in my app store
CloudSync integrates numerous cloud storage tools and is exclusively available on TOS5 and later versions. Your F2-210 is limited to using TOS4, thus making it incompatible with CloudSync. However, you can still access alternative cloud storage solutions within the TOS4 application.
donngmurphy
Post by donngmurphy »
Make sure your TOS version is up to date and your model supports Cloud Sync, older versions or unsupported models may hide certain apps.
Return to “CloudSync”
