[F5-422 4.1.27] - slow SSD write
seba22
Post by seba22 »
Recently while testing I decided add SSD drive as cache for my F5-422 - (HDD TRAY 5).
After enabling cache i noticed that my performance on writing to NAS went down.
I start trying to diagnose what can be wrong. I replace SSD drive for another vendor but still no luck.
I SSH to TOS and perform write test to SSD directly
dd if=/dev/zero of=/dev/sde
dd: writing to '/dev/sde': No space left on device
468862129+0 records in
468862128+0 records out
240057409536 bytes (240 GB, 224 GiB) copied, 4631.99 s, 51.8 MB/s
same speed i got on another company ssd (around 50MB/s) with is totally bad for SSD.
for sequential write i would expect at least 200MB/s
I tried doing blkdiscard
blkdiscard /dev/sde
But no positive effect.
I expect maybe something is bad with hardware but read test prove that sata interface it's working fine.
 dd if=/dev/sde of=/dev/null
468862128+0 records in
240057409536 bytes (240 GB, 224 GiB) copied, 585.658 s, 410 MB/s
410MB read 0 that is totally fine.
Have You got any idea what might be wrong?
Re: [F5-422 4.1.27] - slow SSD write
Hi, thanks for the reporting. We will test here first and get back to you later.
May I know your installed HDD and SSD model number, and created RAID mode in return?
seba22
Post by seba22 »
RAID 5 created from 4 HDD drives (the same model) visible bellow:
SSD actual mounted:
As for writing from your computer to the NAS, is it possible that the speed may be related to the performance of the computer?
And make sure your SSD is at healthy condition.
