F4-210 Yandex disk program does not work
AlexPo
Post by AlexPo »
Yandex disk program does not work.
Installed the program, but it does not work. Installed two-way synchronization, but it did not create a disk shortcut in NAS.
The program does not work in TOS4 or do I need to do something extra?
Re: F4-210 Yandex disk program does not work
Sorry but there is no "disk shortcut" feature as you mentioned. Reading and writing to the corresponding local directory can achieve a similar effect.
AlexPo
Post by AlexPo »
I am worried that nothing happens at all and is not synchronized. That is, there are no results from the program's work.
Return to “CloudSync”
