Expand Volume /
joedirt
Expand Volume /
Post by joedirt »
i have a 2tb OS drive but the / partition appears to be running out of space. how do i expand this partition?
Thank you
Model F4-424 MAX
TOS 6.0610
joedirt
Re: Expand Volume /
Post by joedirt »
--- Volume group ---
VG Name vg0
System ID
Format lvm2
Metadata Areas 1
Metadata Sequence No 3
VG Access read/write
VG Status resizable
MAX LV 0
Cur LV 1
Open LV 1
Max PV 0
Cur PV 1
Act PV 1
VG Size <1.81 TiB
PE Size 4.00 MiB
Total PE 474291
Alloc PE / Size 474291 / <1.81 TiB
Free PE / Size 0 / 0
VG UUID S7whf1-Yfcx-kTad-MBVP-4zM4-iqW1-JdRo3A
VG Name vg1
System ID
Format lvm2
Metadata Areas 1
VG Status resizable
MAX LV 0
Cur LV 1
Open LV 1
Max PV 0
Cur PV 1
Act PV 1
VG Size 10.88 TiB
PE Size 4.00 MiB
Total PE 2853386
Alloc PE / Size 2853386 / 10.88 TiB
VG UUID PvCRk7-yifU-pflp-tRDA-rYwj-ERjW-Blk98J
Re: Expand Volume /
It should not be that full (presuming you mean the 8GB (nominal 7GB) Operating System partition.
If you mean Volume 2, and you don't (think you) have that much data, may be excess snapshots/orphaned snapshots are using the space which has happened more often than you would think.
If it is simply you need more disk space then doing that will depend on how you have your nas set up. (Raid type, occupied slots, etc)
Re: Expand Volume /
This situation is likely caused by you accidentally choosing the system root directory as the destination for some downloads or backups.
Please try opening Terminal and entering the following command to check the occupancy of each folder in the root directory:
cd /
du -sh *
Additionally, this should not be related to snapshots.
Re: Expand Volume /
I just saw both of your / root system partition and volume 2 going to be full. which one you want to expand?
For the root system partition, you can't expand it, you need to remove some data you storage on this partition. For volume 2, I saw there is quite plenty space on your volume 1, you may use volume 1 for future new data storage.
