The search is case-sensitive. It searches for the word in exactly the letters it is written
A contents search engine for business
AES
Post by AES »
The search is case-sensitive. It searches for the word in exactly the letters it is written.
'Example' and 'example' are different words for it.
TerraMaster F8, TerraMaster F2-425, Syno 218+
Re: The search is case-sensitive. It searches for the word in exactly the letters it is written
Your point being?
AES
Post by AES »
Usually, a standard search string should ignore whether the letters are lowercase or uppercase, and search for any occurrences.
The queries 'terramaster', 'TerraMaster', 'TeRRaMasTER' should give one search result.
But Terra Search searches exactly as written, and only in file names without searching by folders.
AES wrote: 08 Feb 2025, 23:28 Terra Search searches exactly as written,
Thanks for clarifying which search function you were discussing.
Return to “Terra Search”
