Is there a way of using scp for transferring files? I always get the message "connection refused"
Thanks for your help.
How to unblock scp
Re: How to unblock scp
Hello, have you configured the SSH service through Control Panel under Network Location settings?
Tell scp to use the secure port (as in ssh setting) since scp default is 22 (which is not open on my Tos6).
Hello!It is suggested that you first try to connect to the TNAS via SSH using a command on your local computer.
It is best to use the super administrator account to connect.
ssh -p 9222 username@ipTo contact our team, please send email to following addresses, remember to replace (at) with @
Hey, thanks for your reply. I already loggen in via ssh like you posten above - this works perfectly.TMqiky wrote: ↑05 Feb 2025, 15:15Hello!It is suggested that you first try to connect to the TNAS via SSH using a command on your local computer.
It is best to use the super administrator account to connect.Is it possible to connect successfully using the above method?Code: Select all
In the meanwhile I also tried sftp - this also works. It's just about the scp...
