Time Machine Service Keeps stopping
Time machine backup for macOS users
sim667
Post by sim667 »
Im running TOS 5 and I keep having to re-enable the Time Machine service as it stops itself in backup. When the service is running the backup happens without an issue. Has anyone got any insight as to why it might be stopping itself?
EthanLiu
Re: Time Machine Service Keeps stopping
Post by EthanLiu »
sim667 wrote: 03 Feb 2025, 17:52
Based on your description, the following are possible causes for analysis:
1. Network Issues: If a network drive is used as the backup destination, network instability or configuration errors may lead to backup interruptions.
2. Insufficient System Resources: Insufficient system memory or high CPU load may affect the normal operation of Time Machine.
3. Corrupted Backup Files: Errors occurring during the backup process may result in corrupted backup files, causing Time Machine to stop the service to avoid further damage.
4. Incorrect System Settings: Improper settings of Time Machine, such as overly frequent backup schedules, may cause the service to keep stopping.
5. Incorrect System Time or Time Zone: Incorrect system time or time zone settings may affect Time Machine's backup schedule.
The specific situation needs to be addressed based on your actual circumstances. You can conduct a simple troubleshooting based on the above content. If the issue remains unresolved, you can contact the online customer service through the TerraMaster official website, and we will arrange technical support for remote assistance based on your situation.
fnfunkin
Post by fnfunkin »
I’ve run into Time Machine stopping unexpectedly before, and in my case it turned out to be a flaky network connection to my NAS. After stabilizing the network and restarting the backup, it worked normally again. I’d also double-check system resources and disk health since those can quietly cause interruptions fnf .
Phil
Post by Phil »
fnfunkin wrote: 24 Mar 2026, 11:40 I’ve run into Time Machine stopping unexpectedly before, and in my case it turned out to be a flaky network connection to my NAS. After stabilizing the network and restarting the backup, it worked normally again. I’d also double-check system resources and disk health since those can quietly cause interruptions fnf .
Your summary is spot on. Users experiencing Time Machine interruptions can refer to your method. Thank you for sharing such valuable insights!
Return to “Time Machine”
